Here is my situation, I have a 150 V-6 (xp) and it has been running rough in the 1500 RPM-2000RPm Range, so I decided to check the plugs, and do a quick once over, replaced the plugs, because they where fouled, replaced the fuel line because it was dry cracked, and cleaned the carbs. Took it back to the lake and ran it again, still the same problem, I have heard that stators and timing sensors go out in these so I looked under the flywheel and noticed after getting off the lake that the epoxy on the stator was melting and dripping down onto the top of the power head, so I proceeded to replace the stator, and timing sensor figuring that was the problem, and I also checked the voltage output to make sure the regulator wasn't bad, max output voltage was 14.7 volts. So after replacing these parts, I went back to the lake, and still the same problem?? The motor runs great on top end but if I am idling it around or hold it in that 1500-2000 rpm range where it is running rough, it will die if I suddenly shift it to neutral, or if it does stay running it dies if i shift it into reverse, then it will start back up and do the same thing.
I sprayed carb cleaner around the power head to see if I have any leaks, and I sprayed around the throttle shafts on the carbs to see if they where leaking and nothing happened. I am getting frustrated and would like to see if anyone out there has encountered this type of problem? Any help would be greatly appreciated!
