Gas tank mix up
thefairlaneman
Banned
I know this may be a real dumb question,but why wont a evinrude tank work and not a mercry tank. I took the mercury gas line and replaced the tank connection with one from a evinrude but something seems wrong,,HUH?
dlplost
Re: Gas tank mix up
should work, maybe just a bad "o" ring?
I had a Mercury tank that worked fine on a 90, but not on a 50, turned out to be an old "o"ring that sealed on the 90 but wouldn't on the 50, let it suck air.
emckelvy
Re: Gas tank mix up
You got the flow arrow on the primer bulb still pointing in the correct direction (to the motor not to the tank)?
Other than that I can't think of any reason it wouldn't work. I have one test tank with Merc fittings and I made up an adapter which plugs into the Merc fuel connector, with an OMC fitting on the end for running Johnrudes. Works great and a lot simpler than having to mess with 2 tanks and 2 hoses!
HTH........ed
