budsbud662
Thread starter- Joined
- Apr 15, 2008
- 66
I have a 96 Johnson 150. It has extremely low hours, When i take the cover off, everything looks like it did on the show room floor. It runs Great, The problem is, I go on a 10 minute run, fish for 2 hrs, i go to start the motor and it idles and coughs. i get on the throttle and it dies. once i repeat this prodcedure i get on her, she stutters for a second, and then takes off and runs fine. if i stop it idles fine. it only does it on a warm start. and occasional cough at cold start, but never dies on cold start... Does anyone have an idea? it has a new VRO pump. i also get an occasional "no oil light" at idle. I had previous low fuel pressure problems that i bieleve were solved by a loose hose on a carb, i dont know if the problems are related.. once the motor is running and done coughing. it gets on plane great. the motor runs, sounds and looks good. doesnt seem to be any problems at WOT.
Is there a way to find out what cylidner is causing the cough? or miss?
Does anyone know how to fix this?
The guy that had previously owned this motor traded it in for a new etec because of the cough. i got a great deal on it knowing you guys at iboats will help me get it fixed. the motor has far less then 100hrs on it.
