1883 alpha one gen one lower shift shaft
driller80545
How hard is it to replace the lower shift shaft seal? Is the bushing threaded into the housing? Any tricks? Thanks, Steve
driller80545
Re: 1883 alpha one gen one lower shift shaft
For some reason I can't open up the manuals link. I get an error message saying the file cannot be found.
Uraijit
Banned
So is it necessary for the gears to be removed, in order to pull the shift shaft? I think mine's leaking too.
driller80545
Easy as pie, just unscrew the bushing and screw in new one with seal and new o ring. Ha.
Really easy. Don't forget your e-clip under your bushing, grease the inside of the seal and perfect seal the outside of the bushing. Don't miss any o-rings...
