Filled Engine Transom Mount Holes
atengnr
Hello. Just looked to know if this is an OK repair. Filled transom engien mount holes, drilled them out to 3/4" due to hole irregularity, used epoxy resin on 3/4" dowels and inserted into holes. I left perhaps 1/8" to 1/4" space on either side of dowel for epoxy filler.
Is this OK?
Thanks.
karlow1
Re: Filled Engine Transom Mount Holes
It sounds good it the wood was dry after you boared them out to the larger size.
KP
OV1961
That's what I'm doing except using 5/8" dowel and 3M 5200. I'm not planning on leaving a space because I'll have to grind the fiberglass down and the dowel will go down with it.
