johnson water pump
iceman1
i have a 1962 johnson electramatic 40 horse motor that i just got runniung. my problem is i don't see any water coming out any where. i thought it would come out with the exhaust. should i be looking somewhere else? where is the pump located? any idea on the cost for meto install a new one? thanks for the help.
tashasdaddy
Re: johnson water pump
the motor must be submerged atleast 1/2 way up the leg. the pump is the the bulge of the leg. it is not self priming, and must be submerged. you should get mist or droplets, out of the 2 exhaust relief ports on the middle back of the leg. the rest goes out the bottom exhaust.
iceman1
thanks, i was useing water muffs and not getting anything out that i could tell, i woll put it in a drum of water and see if that helps. i will let you know how it turns out. thanks again.
iceman1
that did the trick:) i can see a fair amount of water droplets coming out the exhaust so i'm guessing it's working. i let run a few minuites and it ran well. my only problem now is when i turn the key off the engine still runs till you choke it out. i dont want to keep doing that, i dont want to ruine my plugs. any ideas? thanks again for the help.
tashasdaddy
if i am not miss taken, that motor cannot be run on muffs. the water pick up is the screen, on the bottom side of the fin above the prop, where the exhaust comes out. you may have just burnt up and impeller, running it dry.
