OMC hard shifting....
JustJason
This has been done a million times before I know, but I've searched the archives and can't come up with a schematic or TS chart. Anybody have one? :)
1990 OMC 4.3 cobra with a clutch dog...
Goes into gear with 2 fingers...
doesn't want to come back into neutral easily...
engine idle is 575 in gear
the 2 microswitches work, i metered them out, they have continuity when pressed at almost 0 resistance (like .2 ohms or something)
but the esa is not cutting the engine, even if i press the switches by hand.
all of the wiring inbetween the esa and the switches and coil "appear" to be connected and in reasonably good condition. The weatherproof connecters were super clean on the inside and there's really no wire rot in the back of the boat.
Also... anyone know for a fact if i can just take out the esa and hotwire the switches to make it work like a merc? (i'm a poet and I didn't even know it) hehe.... thanks Don.
Don S
Re: OMC hard shifting....
Yes, it can, but you wouldn't want it idling that slow. 650 to 700 and it will work.
I posted a drawing on what to do, let me see if I still have somewhere.
Don S
JustJason
If i'm reading that correctly, On the left hand side,
A. goes to ground
B and C are jumped together
D to coil neg
and then on the right side
D and C are left alone
B and A are cut and capped
And then I need to bring the idle up, is that right?
If it is, and just curious, what's the point of grounding A on the left side of the pic?
JustJason
Ahhhh.... just took me a second and for me to draw it out myself on paper to get it.....
Now.... aside from just making the system that much more difficult.... why did omc use that esa module instead of just doing it that way/merc way?
Boatin Bob
If everything is working fine there is less chance of stalling the engine with the ESA than with just the switch.
JustJason
so then what's the point of the esa.... what exactly is it? When i went to boat school we didn't do omc..... (go figure). It cuts out the ignition with an input signal from the microswitches, but what does it do on top of that that the switches can't handle?
Boatin Bob
On a Merc, the switch grounds out the coil for as long as the switch is made so if it's sticky or you shift really slow there is a good chance you'll stall the engine. With the ESA the electronic module pulses the coil so it's like only half the spark plugs get to fire. The result is the same, the engine RPM's drop which take the load off the gears and make it easier to shift out of gear back into neutral with less chance of stalling the engine.
JustJason
ahhhh.... ok. Thanks for your help Boatin Bob and Don, much appreciated!!
bruceb58
Why not just do it the right way and buy a new ESA. The newer ESA's don't need the overstroke switch either.
Also, if the points have been replaced by electronic ignition, the ESA won't function properly.
JustJason
Don, Bondo, rodbolt.... anyone have an opinion of what works better/more reliably? Replacing or rewiring?
JustJason
Re: OMC hard shifting.... bump...
bump
Don S
Never really compared them. And they were done years apart.
For a customer, stick with OEM. Keeps you out of trouble when you try to engineer something to work ............ and it doesn't for the customer.
danond
I have a Pertronix-equipped (with the ESA fix) 1989 4.3 and it shifts flawlessly using the factory ESA. All I get is a little "bump" going in and no noise or additional effort coming out. I don't take all day shifting, either. Quick and decisive into and out of gear and things work awesome.
Do it the way OMC intended and it'll work fine. Replacing the ESA is your simplest route to a solution, really. $60 and you're back in business.
JustJason
funny... i responded to a post the other day about a guy asking to jbweld his block.... i told him i'd never do it for a customer, but if it wasn't bad, sure it can be done....
I should just follow my own advice sometimes.... :) and yours.
bruceb58
You know what else is funny...he will bring it to another mechanic someday and the mechanic is going to say that he needs an ESA but someone rewired it to work a different way. Customer is going to say "Well, that's the way i found it...". You know the rest of the story!
JustJason
[copy=bruceb58]You know what else is funny...he will bring it to another mechanic someday and the mechanic is going to say that he needs an ESA but someone rewired it to work a different way. Customer is going to say "Well, that's the way i found it...". You know the rest of the story![/quote]
I know the end of that story all to often... its going to get a new esa... and that's it. Thanks everybody!!
