1983 Bayliner cuddy cabin, AQ125A/270 outdrive. ... slipping...
RandyJ
Master Chief Petty Officer
Long story. Driver was too rough while pulling towable toy. Now my boat acts like a straight shift car with a bad clutch. Takes off okay but when I give it more throttle it just revs up and doesn't go any faster. I suspect the hub is spinning in the prop. Is there something else I may need to look for? How would you diagnose this problem?
Don S
Re: 1983 Bayliner cuddy cabin, AQ125A/270 outdrive. ... slipping...
Check gear lube. is it low, burned, or millky?
RandyJ
Don... ya mean it acts like an automatic transmission? When low of fluid it slips?
Don S
No, when low on oil, it destroys the clutch cone and bearings.
Check the level (with dipstick) and see where it's at.
