northware5476
Thread starter- Joined
- Jul 8, 2008
- 1
Ran boat after storage for 2 years. Fresh gas, cranked and ran good at all speeds for about 30 minutes. Started running rough at idle speed then shut off. Hard to crank, would barely run with warm up lever on high. Removed cover and noticed fuel leaking at fitting around filter and spraying out the back of filter. Know this is not normal. Is filter bad or is something else causing this?
