Engine stall
rfd27
so i went out to take the boat out tonight, ran fine at idle speed. as soon as i left the marina, i went to kick it up and it stalled on me. After that, anytime i turned the key, i got nothing but a clicking noise from the engine compartment. Wouldnt' try to turn over or anything. I was thinking fuse problem or alt. problem? Any ideas? 224 HP Volvo
rather_be_boatin
Re: Engine stall
Could be a lot of things from what you described. Start at the battery, have it load tested. If okay, charge it and move on to alt., check charge when running. Should be 13.5-14.5 volts. Usually clicking from engine when keyswitch is to starter is a dead battery.
