Murf the Surf
Thread starter- Joined
- Jun 28, 2008
- 4
I am having skipping problems when motor is running over 2000 rpm's.
The motor was running ok until yesterday when I topped off the tank with 11 gallons of fuel. I took the boat out and it started skipping after being on the water for less than a half an hour or so. It skips pretty steadily when over 2000 rpm's but doesn't seem to skip when at idle or when getting on the throttle. It does skip at mild throttle accelerations and once a steady rpm is achieved it skips steady about every 20-30 seconds or so throughout the rpm range.
The Evinrude Service tech says it could be bad fuel. He suggested putting
K100 into the tank and change the fuel filters in an attempt to see if it is indeed bad fuel. If this does not work then bring it in and they will check for a variety of other possible causes such as the Fuel lifting pump, injector nozzels, plugs, timing, ECM etc.
Does his advise seem logical? Is it safe to run this motor while it is skipping? Any advice would be appreciated?
Thanks,
Murf
Thanks,
Murf
