PLEASE HELP!! Mercruiser DIES!!
Maclin
Re: PLEASE HELP!! Mercruiser DIES!!
The intermittent nature of the symptoms you describe are not typically associated with a carb problem.
In my post when I said the negatve side of the coli is grounded and ungrounded I meant that the ignition control unit performs that, and that is how spark is generated. I did not mean for you to try to ground the coil on purpose. I wanted to help you eliminate a bad tachometer as potential source of your problem. You need the other wire that goes to the ignition controller to be hooked up and tight at the coil negative terminal at all times.
goneboating06
Yeah i figured it out about what to do from your previous post... but nope its not the tachometer but thanks for your help i really appreciate it! Thanks
flabum
A very common problem is the kill switch. Try jumping the kill switch wires at the dash (where the lanyard hooks to) and see if that helps.
Dakota47
sell it to your buddy and buy a new boat :rolleyes:
bamadave
Is the shift interupt switch disconnected when the cannon plug is separated?
RJLeuwen
No it is not.
That is the next thing he should disconnect seeing that it is not the boat harness causing the problem.
RJ
MikDee
Banned
Did you check your fuel tank antisiphon valve, & fuel filter? Or maybe the fuel tank vent? Just a few items that come to mind.
DayCruiser
Ensign
I was having a similar problem one time and it was the above. A short in the killswitch. Got that from the great mechanics here. Saved me some time and money thats for sure
Don S
Just run it with a jumper wire from the battery POS terminal to the coils + terminal as mentioned a long time ago. This will tell you if you have engine problems, or helm wiring problems which will cut out about half of your random searching.
goneboating06
Yeah i tried that and its still doing the same thing as before. So it cant be anything from the engine up to the helm. So it has to be something on the engine right.... please correct me if i am wrong!!! Like mentioned above it could be a short in the kill switch but does the kill switch go through the cannon plug?
Don S
You can disconnect that round 10pin harness and the engine will still run with the jumper.
Disconnect the shift interrupt switch and try it again.
goneboating06
I ran the engine with the jumper and the shift interrupt switch dissconnected and its still having a problem.
Don S
How long does it run after you start it?
goneboating06
It depends sometimes 30 seconds, sometimes 10 seconds, and if i am lucky 1 minute.
Don S
Put a jumper wire across the 2 terminals of the oil pressure switch and try it.
Don S
The oil pressure SWITCH, not the oil pressure gauge sender. Should be located on the port side aft of the block just above the oil filter base.
goneboating06
Yes i know the oil pressure sender is on the top of the motor on the right side by the distributor. the SWITCH is on the right hand side of the motor right above the oil filter yeah i know but it only has 1 terminal and i have tested it. Its in good working condition.
Ayuh,.....
That's the Sending Unit,..... The Switch has 2 wires.......
Keep lookin'....
It's mounted down low, postside, just ahead of the oil filter adapter...
goneboating06
I know what the sending unit is and the switch is... i work on engines everyday but my engine only has 1 terminal for the switch. I dont know why it just does.
