JohnnySCV
Thread starter- Joined
- Jun 24, 2008
- 71
Hello, I have a 1978 Johnson Outboard 85 HP engine. The Tilt/Trim is acting up and I'm wondering if anyone could provide a solution as I am not sure replacing the motor is the answer.
When I try to lower the motor (mostly from when it is almost all the way up) the tilt/trim motor just spins almost like something is slipping. I have to go back and forth with the switch to get it to engage, and sometimes I have to use the screw on the side to lower the motor a bit and bleed it to get it to go. I completely bled the system and used a lightweight fluid that the marine store recommended. Again this is an intermittent problem but mostly only when the engine is close to or completely up.
Any thoughts?
Any thoughts?
