Chev or Ford engine ???
garysunbird
In a 1990 Sunbird inboard/outboard , is the 3.0 liter 4 cylinder engine a Ford or a Chev ?
What automobile starter will fit it ?
Don S
Re: Chev or Ford engine ???
No "Automobile Starter" will fit it, it MUST be a marine grade starter.
are you sure this is a 3.0L engine????? if so, it's a GM. If you are sure it's a 3.0, it could be a 2.3L Ford if it's an OMC.
Ayuh,..... Welcome Aboard Gary,....
Like Don says,...
Automotive Starters are Can't be used on Boat motors,...
The Big Reason everybody says is that they're Not Explosion Shielded,+ are a Safety Hazard....
Which is Very True,.... They'll turn a Great day on the water,... Into a Fireball in only a Second.....
Another reason is,..
They don't have the Right wiring terminals to make the Boat motor start properly.....
