How to use the alignment tool
bwingler
Ok all, got the boat engine in, all wired up and running. My alignment tool arrived but there is no instructions for doing an alignment. Anybody know how this is done?
bruceb58
Re: How to use the alignment tool
Inspect the splines on the shaft for visible wear, generally if the splines
are worn then the coupler is also worn. If wear is evident replace the parts
as needed.
NEVER Force the alignment tool in, you can damage the tool and the coupler.
1) Once you have the engine height close enough to
fully insert the tool without force, then you can start
working on setting the proper alignment.
Take your time, getting it close enough to insert the
tool the first time can sometimes be the hardest (most
frustrating) part.
2) Coat the end section of the tool (the smallest diameter
area) with a light coat of grease and then insert it fully
into the coupler.
3) Without turning the tool, pull it straight out and look at
the depth of the teeth marks in the grease.
If the teeth marks in the grease are deep on the
top side and shallow on the bottom side of the tool then
your motor is too high.
If the marks in the grease are deeper on the bottom than
on the top then your motor is too low.
4) Adjust the engine height accordingly.
5) Keep checking the depth of the marks in the grease until
they are equal in depth on top and bottom.
Sometimes as little as 1/8th of a turn on the adjusting nut can be the
difference between being properly aligned, and just having it "close"
Lightly Grease the splines on the shaft (and on the coupler if you can) with
Spline grease prior to assembly.
