Boat leans
Gordonsetter
I have a new alumacraft 18 footer with a new 115hp e-tec engine.. last week it started to lean down on the port side at speeds over 15 mph.. I have checked the prop, lower unit and even crawled under the boat to look to see if there was a dent..
i lost the plug and the boat took on a lot of water before i got a new plug back in.. is it possible i have water trapped in the hull..
marine4003
Re: Boat leans
First off,when boat is on trailer jack up the front ,allow all water to drain...give it a day. Second ,under the cavatation plate on your motor (flat plate above prop) there is a zinc anadode,its shaped like a fin...where is it pointing?12-o'clock? it should be off set to allow for prop torque,move it 2 spaces to the port side of the boat (10 o'clock) give it a try and see if this corrects it,if not or it gets worse move it 1-2 more places,or switch to the 2 o'clock. Good Luck.
tashasdaddy
Re: Boat leans
have you tried adjusting the trim, tucked too far under pushes the bow down, and waves have more bit to control the boat, try trimming out some.
Five O'Clock
Re: Boat leans
i had the same problem with my 25' monterey and these great guys in the forum helped me correct it... my trim wasn't adjusted correctly so thats how i fixed my lean, with the help of trim tabbing as well... at the very bottom of these pages are "related topics"
check those out too for some more info.
