2 strokes is all i need
Thread starter- Joined
- Jun 7, 2008
- 7
my neighbour originally had this motor. it has a problem where it wont pump water at idle. he blew the motor because of this. so he had the powerhead professionally rebuilt. total ignition system overhaul, carb rebuild, the works. he also had a new impeller installed. after he got the motor back together with all new parts, it still has the same problem, so he got pissed and threw the motor away. me being a cheap shake i plucked it out his garbage pile one night.
so now i have this great motor, its got top compression,. starts on the first pull, runs like a dream. but it wont pump water and cool the motor at idle. you can run it all day long at half throttle or full throttle and the cylinder head stays at a good temp, but as soon as you go down to idle it overheats. when i say overheat i mean i shut it off at 220F. i measure the temparture with a portable infrared temparture gun so its pretty accurite. besides, if you spit on the head the spit bubbles so it IS overheating.
first thing i thought was maybe its an impeller problem, so i tore the lower end apart and had a look. everything was lined up correctly, including the impeller keyway. i spun the lower unit with my electric drill and it will pump water higher than my head so i KNOW the lower section is good. also the rubber boot which connects the cooling tube from the imeller housing to the powerhead is in good condition.
so next i pull out the thermostat. it looks new. i put it in a coffee cup with water and heat it and sure enough when the water gets warm it pops right open. if i let it sit and cool the thermpstat closes back up. so its not a thermostat problem.
so finally i thought maybe theres a blockage somewhere in the powerhead, but i pulled the cylinder head off and everything looks clean. if i hook up a low pressure pump to the cooling tube which extends down from the powerhead it flows water through the motor just fine.
so whats going on? im freaking out now. im not a newbie to outboards. and 2 strokes are a passion of mine. but this problem is licking my butt. ive been wrenching on motors for a decade now so i almost feel embarrassed to ask for help.
p.s the motors water pickup port is WELL below the water line at idle or when at speed, or when testing it in a bucket.
