freddyray21
- Jun 10, 2006
- 2,460
Compression 90 lower and just over 100 upper, hoping a decarb and run it will even them out. rebuilt carb, cleaned and reset points, new plug wires, good blue spark with lots of crackle, . It is hard to start cold. Once warm it starts first pull at an idle. Once running it runs great does not miss a beat and idles perfect. Cold start procedure is to prime tank (pressure tank known good as it runs fine on other motor) choke, turn the throttle up all the way and pull like hell until it fires. Seems to be not getting gas. Got it started tonight and did a decarb, but have not checked the compression again yet. I am going to put it on a boat tomorrow and run it before I do a new compression test. Any idea?
