sidechoke67
Thread starter- Joined
- Oct 24, 2007
- 244
I have an open bow boat that will be used mostly for family rides,
tubing, skiing, etc. I will also bass fish from it, and would like to
make some kind of casting platform on the bow. Whatever I do needs
to be removeable for tubing trips, and I really don't want to modify
the boat much. Would love to hear any ideas or suggestions on the best way
to do this.
The bow has 3 cushions. The front most cushion is removeable, the two
side cushions are attached on a hinge. I don't want to remove the hinges,
or have to screw cushions in/out to convert from tubing boat to fishing
boat.
Idea one is to remove the bow-most cushion when fishing, and build a casting
platform only where that cushion was, and over the walkway. This is by far
the easiest, most removeable, and would probably give me all that I need/want.
Idea two is to build a casting platform in 2 or more pieces that would go
over top all three cushions and the walkway. This would give me more casting
room. My concern here is that the plywood would dig into the cushions,
and damage them over time. I could cover the plywood with some sort of
padding, and I/O carpetting, but I would still be nervous about doing
damage over time. My other concern is that the inner sections of the
cusions are about an inch higher than the outside part of the cushions,
so I don't know that the deck sections would be that stable - meaning that
they would be more likely to pivot around, and dig into the cushions.
Anyway, if anyone has done a similar project, I would love to hear about it.
Any other ideas or suggestions are more than welcome. Thanks in advance!
to do this.
boat.
