Running well prior to impeller change
samm835
I have a 3.0 OMC cobra drive. I recently had the impeller changed in the drive, and this was the first time back on the the lake since then. It idles five, but once going for mid or full throttle it boggs down then shuts completly down.It will bogg for a couple of seconds then run out, I can bring back to idle prior to it shutting down, but if I try to stay in full throttle it goes out. Could it now be ready for a carb rebuild or replacement?
Thanks for the help, as always the help on this site is worth a million bucks!!
dazid1
Re: Running well prior to impeller change
Dont want to teach you to suck eggs but I got caught out last week with my outboard doing the same thing and it was the push on conecter to the tank, you will have a built in tank will you? but its worth checking the conections.
Ayuh,......
You could very well be Right,....
But,...
I'd start with the Fuel Filters 1st......
sebas54
Try changing the water circulator pump.
I had similar problems and once I changed the pump all was well.
Ayuh,.... That's a Sure Fire way to fix a Fuel Delivery Issue.......... :rolleyes:
sebas54
I thought that he was experiencing overheating because the symptoms that he explained happened to me exactly the same way, after it overheated a little.
samm835
Thanks for the help, I will get the manual out and find my fuel filters and replace those first. Thanks for the help....I will keep you updated on what I find this week.
samm835
While at work I just remembered something about this that I didn't mention in my first post. The boat will rev ok while in nuetral.....why would it be decent when there and not while try get on plane?
bomar76
Reving in neutral is absolutely meaningless.....no load on engine.
Ayuh,..... Change the Fuel Filters....
