PSS-Mag
Thread starter- Joined
- Jun 17, 2007
- 68
Does anyone have a schematic of 1976 Merc 888 302 v8 ignition wiring?
For some reason I'm not getting power to the coil while cranking.
I have power with key in on position though.
I thought it was the old boats wiring and had ran a wire directly from ignition switch to the coil and used it several years that way.
That boat rotted and then sank last year. I saved the motor drive etc and scrapped the boat. I just put the drive line in a new hull and same issue. So apparently it's the motors wiring issue. I don't know if someone has wired the coil wrong at some point over the years, or if it's a bad wire, or what. Or if it pulls power from the starter solenoid while cranking to the coil or what it might could possibly be.
If I can see a schematic of the pre-ignition ignition system, then maybe I can trouble shoot and fix it right. Otherwise the only thing I know to do is run a direct line from the ignition switch to the coil.
