Doral 190 2000, Horn/Radio not working??
plmskier
Anyone have any suggestions? Under the steering wheel looks like some type of gfi push button breaker/fuse. Can't figure it out.
Paul
kenmyfam
Re: Doral 190 2000, Horn/Radio not working??
Paul
Photo would help. Close up and general.
plmskier
Thanks for the post....actually figured out the problem. Prior owner installed another power lead to the battery. I hoooked it up and it was all set.
Thanks again,
Paul
kenmyfam
Thanks again,
Paul
Glad all is well. Enjoy your boat and to heck with the price of gas !!!! That is my opinion anyway !!!!!
plmskier
I hear ya on the gas! Lot of floating I guess! lol
SOOOOOOO another question. Everything in the boat works fine. Next to that additional wire for horn/radio I found another wire attached to a 10 amp fuse which says bildge (looks like it should be hooked up to the pos on the batt). Currently it is not hooked up and the bildge works. Is that power cord for the auto bildge?? I think it is, not so sure. Just thought it was weird everything worked but it was not connected.
Paul
kenmyfam
Paul
Does the bilge pump work manually only ???
Tryfilling and see if it kicks in automatic. If not then that is most likely the connection for the auto side of the pump and should connect to the float.
Hope this helps. Let me know.
plmskier
Yes you are absolutely right! The manual bilge works, not the auto/float.
Thanks for the suggestion!
Took her out over the weekend and found that the Speedo was not working. I know the dealer removed the lower unit for maintenance. I talked with them, looks like the forgot to hook up the speed tube that connects to the lower unit. I found the tube, hooked it up, but have not tried it out on the water yet...soon I hope!
Always something first time in the season lol
Paul
kenmyfam
Paul
Glad you found the problem. Regarding your speedo ???? I dont see how removing the lower unit would stop the speedo working ??? Is the unit not at the side with a tube coming from it ???? on the stern lower ??
If so, is the tube connected and / or is it in the correct position (should be in the all the way rearward position)
PhatboyC
Some mercs has the speedo tube connected to the sterndrive. One less thing hanging at the back which I like.
kenmyfam
Did not know that. Thanks for educating me.
PhatboyC
Oh and this was on a B3 sterndrive.
plmskier
Hi,
Thanks guys, found the problem. On the back of the lower unit, there was a hose that was detached, I put the hose back on. I'll have to test it out tonight if I get a chance!
As always...thanks for the help!
Paul
kenmyfam
Let us all know how you make out.
