outdrive does not go down
ag1057
have a alpha 1 drive .brought it to mech .said there was air in line brought it home worked 5 or 6 times.drive got stuck up again.what can the problem be no leaks i see.can it be the pump?air getting in line?
Re: outdrive does not go down
Ayuh,..... Do you store it in the Up, or Down position,..??
JustJason
does the pump kick on when you hit the down button?
