what are the symptons of manifold failure?
inchman
hi i have a 1988 bayliner trophy with a mercruiser 140 hp 3.0l engine. in my search to resolve a misfire ive descovered that my plug on cylinder 4 tastes salty. could this be a result of manifold breakdown. what are other symptons of a faulty manifold?
cheers Gary
Bt Doctur
Re: what are the symptons of manifold failure?
bad riser/elbow would be my first choice, simple to remove and look inside.
next would be the manifold.
Dakota47
look for water in engine oil..:D
inchman
there is no oil in the sump or the rocker cover. would a bad manifold cause a misfire?
TilliamWe
Banned
Yes. If enough water was leaking into the exhaust valve it could run into the piston and not combust.
inchman
sorry there is no water in the oil in the sump and and the oil in the rocker cover, my misfire is about 3200 rpm
getinmerry
Every good mechanic sucks on old sparkplugs while working...and uses old dristributor caps for his Lucky Charms in the morning.
Dakota47
Thats good. check the rotor & dist cap.
inchman
there is 0.008 play in the distributor shaft, not good i know maybe a change to electric like pertronix would help. the salty plug is still a worry
bruceb58
The play in your distributor shaft will effect your dwell if you have points. The pertronix would help that situation.
I need to know...what prompted you to taste your plugs? Is that some sort of Irish tradition?
Coors
I've smelled plugs, but never thought about a taste test. And wouldn't know what each taste meant.
subcrx
check for steam. remove your oil filler cap. Couldnt figure it for the longest time till it was too late.
Ed R
First of all, number 4 cylinder is closest to exhaust elbow, there is a check valve, which we call a flapper valve that keeps water out of exhaust system. Usually, when this valve fails, number 4 cylinder is the first to encounter water intrusion.
ER
subcrx
I wouldn't rely on the flappers for much.
fishmen111
With no signs of water, I truly doubt that it is the elbow/manifold. Every time I have lost one, it would still run beautifully even with extra quarts of water in the oil:eek:. For a specific rpm miss, I would question the plug wires, coil, dist. cap and/or distributor itself. Have you tasted any of those?:D:D Have you given it a complete tune up? If not, I would along with a compression test (first).
inchman
ill give you abit of back round. lol at the end of the season last year i noticed the boat going on 3 cylinders. I changed the plug leads, points, condensor and cap in the hope that it was something easy fixed. still 3 cylinder ( and running sweet) did a compression test no3 had 20 or 30 psi compared to 130 on the rest. I pulled of the head and the exhaust valve on no 3 was fried, got 2 new valve for no 3 and had the rest of the valve and seats reground, i put everything back together with new head and manifold gaskets and it wass running sweet. put the boat in the water and it started to miss. cleaned the carb, still missing. I noticed water air bullling up fron the port between cly 2 and 3 and this prompted me to taste the plugs ( they looked great maybe a bit white) and thats where i am now.
cheers Gary
gooders
Only last weekend I had a misfire on my 3.0L, turned out to be a loose wire on the coil.
Just a thought but sometimes the problem is so obvious its missed.:redface:
Dakota47
Replace the guzenhowtion.:D
Boatist
I would do another compression check first.
Signs of bad manifold or leak at the riser gasket is, Number four plug looks cleaner than the rest. also in salt water the may see sign of rust. Engine will miss and pulling off the spark plug wires one at a time you will usually find number 4 missing. Number 4 is usually the worst because when the water get into the exhaust chamber it runs down hill to the lowest cylinder and that is usually number 4.
Also when first start getting water into the exhaust the miss will only be at low RPMS.
Running on Muff can see steam coming out the exhaust.
If it gets bad enough then will start seeing water in the oil.
Also if one cylinder fills with water you will not be able to turn the engine over with out pulling the plugs.
When you had the head off did you check for a cracked Block. Also did you drain the block before the winter.
