finally splashed down....but
Status
Not open for further replies.
s2gots
Yesterday was the first day of the season for me...was a very good day out at New Melones lake,( for those of you that are familiar) the boat ran very good, except this thumping noise that happened about 3 times or so...this is the situation-siting idle, move lever forward and boat starts to move, less than 5 seconds later, a slight thump noise coming from the outdrive I assume. It happened when I eased on the throttle, and it also happened when I mashed on the throttle. Other than that it ran good...anyone know what this might be???
88 4winns
5.7 with Cobra
TIA
Re: finally splashed down....but
It is likely your gears slipped momentarily. It will likely get worse as time passes. Make sure the shift cable is adjusted correctly. I am not an expert on Cobras, but on a MerCruiser, we would adjust the shift cable to give a bit more movement into forward gear...
You might post this in the I/O Forum.
tashasdaddy
clutch dog going, try the cable adjustment, or it will just get worse.
gcboat
Excellent post Coors. And yes, they are finicky critters. Thanks !
Coors
But, adjusted correctly, works good.
s2gots
thanx guys, Ill post this in the I/O forum and see what they say...
Don S
Posted in IO forum by s2gots.
Thread closed
Status
