Lower Unit Removal
SteveNix
1998 Mercury 8HP
was driving down the river when all of a sudden the motor started reving and I slowed down to a stop.
Trying to get the lower unit off to take a look at the driveshaft, but It seems the shift shaft is keeping the unit from comming off.
Where do I disconnect the shift shaft from the lower unit?
Thanks in advance
Laddies
Banned
Re: Lower Unit Removal
On the port side under the carb there is a retaining pin
SteveNix
Laddies
I can see the retaining pin, but a little unsure of how to remove it.
Do I have to remove the 4 sided nut on the starboard side of the motor to take the pin out?
That nut it so tight I'm worried about breaking something trying to get it off.
Thanks
Stephen
Laddies
Banned
Rotate the clip 90 degrees clockwise and remove it, you will also have to loosen the screw in the rev, latch actuator
SteveNix
That's the clip on the port side where the shift shaft enters the housing?
I appreciate the help!!! Thank you
