89 115 ETLF Timing question- pointer reset needed?
Popster
1st. step in manual is to use dial indicator on piston to position timing plate (indicator). Then paint over screw to discourage tampering with the adjustment.
My question: Do you have to repeat this step in checking over engine. My guess is no, but thought I would ask to be sure.
Thanks.
rodbolt
Re: 89 115 ETLF Timing question- pointer reset needed?
unless tampered with or the crank or flywheel got changed, no.
Popster
Thanks!
