Re: 69 Johnson spark Issue!!!
May need a new coil condensor and spark plug wire.
Are you checking it by grounding the plug wire or with a spark tester?
Or are you grounding the plug itself against the powerhead? If so check the wire by using a spark tester or you can use a screw driver and bring it up near the powerhead to see what happens. To play it safe buy a spark tester (from any auto parts store) if you don't own one and check it if you haven't already done so. Testing the wire (not the plug) will tell you if the coil is the problem or not, if you are getting spark through the wire then you can just simply replace the spark plug.
Welcome to Iboats.
