Speedometer
fisherovmen
My speedometer slowly failed on my Lowe 1600V, 1989 Evinrude 50, yesterday I got no response from it at all. Where do I start to look for the problem?
Thanks, God bless, Mike.
Re: Speedometer
Ayuh,......
Pull the little Tube off the back of the gauge,+ Blow it out.....
It sounds like it's Plugged up.....
ziggy
Re: Speedometer
if yers has one of the pitot tubes off the transom, that'd be a good place to start. might be fliped up, or have some debris in it....
if ya really wanna know how fast yer going, use a gps....
F_R
Re: Speedometer
If the pitot and/or hose aren't plugged up, then the speedometer is probably toast. If you don't already have one, a tachometer is a nice thing to fill the hole with after you toss the speedometer.
ziggy
Re: Speedometer
i didn't even have to toss mine, i never had one. my '75 came from aristocraft with a tach and no speedo....;)
fisherovmen
Re: Speedometer
As usual, so many helpful people! I will check both ends of the cable unit. I do have a tach, and my Garmin unit measures speed so the speedo is kind of redundant, I just like to keep things on the boat in working order as they were when I bought it. Thank you all very much!
Mike.
Re: Speedometer
Ayuh,.....
There's No cable,.....
It's a piece of Tubing,..... The gauge measures Pressure.....Which equates to Speed......
fisherovmen
Re: Speedometer
Ziggy pegged it, the tube was flipped up! Problem solved. Thanks!!!
God bless, Mike.
CharlieTx
Re: Speedometer
God bless, Mike.
Is the pitot tube white? Also, which GPS would be recommended? I've heard there is a Marine GPS, but it does not operate like the regular ones, while out on the lake. It just gives reference points. I have not used any type GPS, up to this point, just curious. Thanks, in advance, and thanks to iboats for such a great forum! CharlieTx
