How heavy is my Mercruiser 224CID
Fletcher165
Help!!
I'm from the UK and have a fletcher arrowbeau 17GTS with an inboard. Basically, i'm trying to find out how heavy the engine and drive are. It's a 1989 (ish) Mercruiser 3.7Lt -224CID (4cylinder) 165Hp attached to an MR drive.
Can anyone help a newbie and tell me how heavy the engine and also the drive are, as i've trolled though the internet with no luck :confused:
Re: How heavy is my Mercruiser 224CID
Ayuh,.....
The Outdrive itself weighs 80lbs.....
The Transom Assembley is probably 40/ 50lbs....
The Motor,... I'd guess at 300/ 400lbs.......
Haut Medoc
Welcome to iboats........:)
The engine undressed, (no manifold, riser, carb) weighs approximately 200 Kg......;)​
