I have a 1981 50 hp 4 cylinder mercury and i am having an issue with the fuel getting to the motor. I changed all of the fuel lines, gaskets in carbs, primer, valve at the motor and gas tank and it still is runnig rough. It will lose a little power and if ou pump the primer it will boost the power back up. I have tried everything. thanks for any help you can offer.
