kwoolard
Thread starter- Joined
- Feb 9, 2003
- 420
I was wondering how accurate are marine temperature gauges? The temp gauge that I have has a range from 120-240 degree F. It has number increments at 120, 180 and 240 with one tick mark between the 120 and 180 and one between the 180 and 240. I am assuming that the tick marks are 30 degree increments. While running the boat this weekend I noticed that my temp was staying just below the second tick mark, which should be 150. Therefore, according to the gauge it was running say 140. My infrared temp gun read 162 at the temp sender and around the thermostat housing, which has a 160 degree thermostat. Can these gauges be that far off or are the increments on my gauge not necessarily 30 degrees? I used a teflon paste instead of teflon tape on the sender fitting when installing, would that have an effect on it as well?
Thanks
Keith
Thanks
Keith
