Frank Acampora
Thread starter- Joined
- Jan 19, 2007
- 12,004
Today I took Amanda Ford out onto the river for her pre-season shake-down run. Everything went well. I changed a couple of props to check performance and nothing was amiss. I ran the Chrysler 140 for about ten minutes on the last prop change then put Amanda back on the trailer.
After dragging her out of the water, I spun the prop by hand as is my habit. I heard a grinding noise that went away. Since The boat was on the trailer and I was going home anyway, I decided to check it at home.
Pulled the prop in the driveway and --lo and behold-- The two screws holding the anode had loosened and the anode had driven itself up into the prop hub. I had to drive a screwdriver between it and the hub to free it. Those two screws were held in with lock washers and they were grunt tight with a screwdriver, yet they worked out. No damage was done other than a couple of nicks in the anode here and there and one screw ground flat. However, continued running could have resulted in damage to the gearcase housing or the four spool bolts. Of course, I replaced the screws with 3/8 head bolts and really laid into them. If that doesn't do it, next step is Loctite.
MORAL OF THE STORY? When your engine talks, listen! Investigate any strange noises you hear--even if they stop.
