Spark only on one side of engine 1988 excel
MAKO72
I am only getting spark on port side of engine. I checked with spark tester. The engine will idle so I cranked it and removed the three plug wires on starboard side and it made no difference as I pulled them and it kept idlieng (rough).
MAKO72
Re: Spark only on one side of engine 1988 excel
Just tried switching wires that go to powerpacks and problem switched sides. Stator? Anything else that would cause this. Also disconnected main plug from controls and switched connectors to a-b.
MAKO72
^ Anyone have ideas stator, timer base, switch box, computer any help please Thanks
MAKO72
Could my problem be related to a sensor, alarm etc.
rodbolt
there is only one cdi, what wires are you switching and can ya post the engine model number ?
MAKO72
Here are the numbers v6excellg 6k7 L 300750
There are two black wires with white stripe each one branches to three connectors that plug into power packs (they are marked 1,3,5 and 2,4,6)The 2,4,6 side had spark but the other leg is dead. Thanks for your help
MAKO72
I just realized with kill switch clip removed I am not getting buzzer with key in the on position could this be related.
MAKO72
Just tested stator ohms and got readings of 54 k on two wires and 2.2 on the other two. I dont have a dva meter
MAKO72
Sorry did test wrong here are the right numbers.
stator:brown-red leads=1140 blk/red-blue=25
trigger=375 on all pairs
All the numbers seem to be in specs?
Not quite sure how to test CDI any help
MAKO72
I just checked stator and triggers to ground. I unscrewed all wires from box and each one gave a reading of ol open. Out of curiosity I touched the red lead from tester to the individual screw holes and those did give readings that varied from 1 to 3.5 (Dont know if that means anything). Thanks for your help.
rodbolt
while I prefer DVA readings your resistance numbers are about dead on.
to test your horn turn the key on, dissconect the pink temp wire sensor and take the engine harness side to ground. if the horn sounds the horn and circuits are working, if not start checking.
retest your spark after removing the pink wire from the CDI.
then dissconnect the micro-processor and retest spark with the A and B connctors hooked together. it should not make a difference but it can.
used CDI's are avalible, Ray may have a few and so may I.
Ray Neudecker
Double check your ground connections on the CDI and other electrics before replacing CDI. As Rodbolt says, I have plenty of good ones if that doesn't work. neudecray@hotmail.com if you need one.
