Sprockett
Thread starter- Joined
- Mar 22, 2008
- 48
Attached is a picture of the splashwell on my 74 Glastron Sportster, it seems that when they attached the new engine they blocked the drain hole for the splash well. So now I'm left with this and I'm not sure how to fix it... I first thought maybe the hole was just plugged but it looks like the engines mounting plate on the transom is blocking it....
I was thinking that it might be a good idea to add a bilge pump to the boat anyway, the drain hole at the back of the boat is accessable from the inside right where the fuel tank sits. So if I can't get past the engine can I hook this to a pump or something along those lines to get the water out of the boat.
Also in the fuel tank area under the splashwell (not sure what you call that area) they put in foam blocks on each side, I'm pretty sure that's not original so unless someone here can tell me why it's there I think I'll remove it so I can clean that area up, get some more space for a bigger fuel tank some storage.
Since this is our first boat we want to get everything cleaned up and right before we take it out to the lake. I hesitated on the foam because I wasn't sure why it was there, but the wood that's there needs to be glassed to seal it in, and that's going to happen before we go to the lake...
Thanks
-Paul-
Thanks
-Paul-
