Re: Soft Spots on floor
Okay, all that said, I think we can all agree that we recommend you don't just let it go and hope for the best. Make sure you carry your PFDs, wear them if possible, and try not to take the boat out in rough weather. Be aware what you're risking, which is death by drowning.
There are a few ways to check your transom, which is the number one most critical thing for an outboard boat. If your hull starts to leak your floatation should keep you from drowning long enough for someone to help. If the transom lets go you may be whacked in the back of the head with a running outboard shortly before the entire lake rushes in at once.
Check the mounting of your outboard... you're looking at the places where the big clamps grab the transom. Look for small cracks around the attachment points, check to see if the clamps dent or push in the surface of the wood/fiberglass. Look for any cracks leaking water, or with a drainage stain dropping down from them. Try pushing down on the outboard with one leg while you watch the transom mounting... it should not flex at all. Finally you can do the knock test... use a piece of metal or a small hammer to tap the transom in several places all over... good wood sounds sort of ringing, and wet wood makes a thud. The trick is to listen right after the initial sound made by your tap. If you really want to be sure, take a 1/8 drill bit and drill test holes from the inside of the boat in places near the bottom of the transom, around the motor mounting, and anywhere you think water may have been pooled. If you get anything but clean white shavings, it's wet. Plug the holes after with epoxy or marine-tex.
If your transom is wet, mushy, or flexes, don't use the boat at all. If it seems ok, you could use the boat on calm, warm days when everyone has their PFD, and you don't mind swimming unexpectedly.
Remember what you're risking... a boat isn't like a junker car. The car breaks down you're walking, the boat breaks down you're swimming. Most people can walk farther than they can swim.
Erik
