How fast?
jasono2l
I have a 17' Rinker (V170) how fast do you think it will go with the Johnson 135 that is on it? The hull is fiberglass and the boat weighs about 1000 ponds without passengers and gear.
Thanks,
Jason
kenmyfam
Re: How fast?
All depends on your set up. If your set up is really bad you will have trouble making it plane out. If it is good then you should be expecting 40 + MPH
My set up in my signature pulls 47 mph (GPS) with 4 adults aboard, however it still pulls the same speed with just me and minimum gear.
Let us all know how you make out and experiment with the set up (trim, loading, motor height etc) till you find the optimum performance.
