Hi guys, I know that this subject was discussed many time, but after checking out about 60 some post I can't find an answer to my problem.
Model 85tl79, I'm able to tilt/trim up and down manually (green with +, blue with - it goes does down) (blue with+, green with -, it goes up) the problem is that engine came originally with a 3 wires tilt/trim motor, the last owner change the motor for a two wire one(green/blue), he told me that the only thing I needed was a relay, but that engine came with a solenoid . If I connect everything like the book says, I'm missing the ground wire from the tilt/trim motor since it's a two wire type motor. Could that explain why I can't get it to work(not having that ground wire from the motor) ?
Marc..
Marc..
