Theoutdoorsman
Thread starter- Joined
- Mar 6, 2003
- 681
I'm having a problem with my recently rebuilt 1979 Evinrude 140. My problems began when I noticed this......
This photo is of the wires, running from the stator, to the starboard side power pack. Notice it has been rubbing the flywheel and the wire was exposed. I peeled back the cover, for illustration purposes, so you can see it was obviously worn. I repaired the frayed insulation via rapping it with some electrical tape and securing it snuggly against the top of the block and out of the way of the flywheel. The reason I found this was because my motor would not turn the usual rpm's and had a knocking sound. I thought I may have had a rod bearing going bad. Once the wire was repaired, I noticed a MAJOR difference in performance. However, I am still puzzled at WHY the outboard is still not performing up to it's full potential. I used to be able to turn my current prop at 5900 rpm's all day long. Now, it will run flawlessly at 5200 rpm's all day long, but, anything beyond that and it is as if someone reaches over and pulls the safety lanyard. Compression is fine. Carbs have been rebuilt numerous times. I've linked and sync'd as per the manual several times, and still the problem exists. Anyone have any other ideas on this? Here's a link to the original thread. It may shed some more light on my findings....... http://forums.iboats.com/showthread.php?t=190100&highlight=Theoutdoorsman ....... Any further advice or idea's on this would be much appreciated............. ALAN
EDIT: Just for the record, the motor run's and sounds great!!! I ONLY have problems when accelerating beyond 5200 rpm's and that as long as I opperate within this rpm range, it will run absolutely flawlessly the entire day long. I'm certainly stumped. I'm thinking a new power pack may be in my near future. I just wanted to pick the brains of some other folks in-the-know prior to making a purchase and wasting money. Thanks again.
