FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
I am thinking of installing a pocket door to my den but cannot find enough illustrated diagram on how to install one. I tried google it but not enough details on how to do it. Can someone help me on this little project. Thanks.
I just finished helping my neice and her husband install one. Lowes sells a kit, which consists of a track and frame, basically. You supply the door, and hang it on the track. It's very easy, actually.
If you're installing it in an existing wall, you will need to demo the wall where the door will go into the pocket, in order to install the frame. Then you'll have to re-drywall it.
In the picture from Popmechanic there is no header, question is don't you need a header at the top of the door so that it don't sag in the middle? Thanks
this trick only works for 2 x 6 walls so if your building a wall for a pocket door read on. Using a 2 x 6 scribe 1 1/2 to both sides of your bottom plate, cutting out the 2 inch in the middle that s where your door pocket is. use 2x4 side ways instead of the metal studs they give you in the kit. pocket doors from the kit tend to have a flimsy wall, plus you cant hang big stuff off the wall. maybe that will help you
