Pursuit2550
Thread starter- Joined
- Sep 20, 2007
- 73
I decided to change out my sculppers and the thru hull drain tube on my boat. When I took out one side I noticed the wood was damp but was not rotten. When I took out the other side that when my problem began. The other side has some rotten wood, I was able to actually dig some out. Its not alot maybe 1/4in deep 1/2in wide. Now I was a little worried, so I put my finger in the hole I dug out and had my wife jump on the outboard to see if I felt any flex. The whole boat moved, no flexing was felt in the hole. What can I do to make a good lasting repair. Replacing the transom is out of the question since it would cost a arm and leg and there are no signs of it being bad, no stress cracks anywhere inside or outside of the boat. Should I Rot Doctor, Git Rot, Marine Tex, let it be and seal real good with 5200,what I am confused on what to do.
Thanks
Thanks
