Does this motor have a charging system on it???
PHOTOG
Hey guys, I have an older mercury outboard I think from the early 1980's serial #5903423 and I was wondering if this motor has a charging system on it? any help is appreciated.
Don S
Re: Does this motor have a charging system on it???
Yes, It's a 1980 Mercury 80EL
Photog, It should have a stator and rectifier to charge the battery. Look around for a black three ring terminal cube. That will be the rectifier
PHOTOG
Great, thanks guys...I will look at it in detail tonight but The only thing I do notice is that there is the standard stuff going into/out-of the engine...throttle, battery pos & neg... but on the throttle control at the helm there is a short wire with a plug coming out the unit, the coupler has 3 pins inside it...could this be it?
A three contact connector on the MerControl is for the Tach. The three contacts are +12V, Ground, tach signal.
On that motor the tach signal is one of the stator leads, and will have a AC voltage on it when the engine is running.
