Hydraulic steering basics help
ted655
Amazing how something that sits goes to hell isn't it?
Got the generator going, now my hyd. steering is "free wheeling", the wheel spins like a roulette wheel. System must be void of all oil.
There is a little bolt on the housing (pump?), just behind the wheel. I assume this is a fill fitting as there is no tank anywhere.
Here is what I'm thinking; Pour 20# non detergent into the fitting while turning the wheel 1 direction. With the fittings loosened at the cylinder on the transom. When all air is pushed out & oil starts to ooze out, then tighten that fitting & repeat, turning wheel in opposite direction while adding oil to fill that line, same as the first one.
OK procedure? Thanks, Ted
Re: Hydraulic steering basics help
Ayuh,...........
Sounds like a Good way to get Started...........
whywhyzed
Banned
then fix the leak.... it wasn't just the "sitting" time, it was the "sitting and leaking" time
Outsider
OK procedure?
I think you'd be much better served by taking your problem to someone who has a clue concerning something as important as steering. At a minimum, contact the manufacturer concerning proper fluid recommendations, and don't be surprized if 20# motor oil is not be on the list ... ;)
ted655
OK procedure?
Ah, would if I could. Not possible in this case. "Morse" is no longer. Also, I'm not in a marina or area where there are lots of typical help is available.
Nope, it's just me & good advice from those familiar with hyd. steering. reread my signature, I'm in the swamp.
Outsider
Teleflex bought Morse, and they have a good customer service. Assuming there are telephones in the swamp, of course ..... ;)
Ayuh,.......
Most Hyd. Oils are about a 10W,......
If in doubt,......
Use ATF.........
ted655
Just drums!
ddennis
Where IS Butte La Rose? I am originally from Monroe, La.... Never heard of Butte...
ted655
Atchafalaya Basin. Henderson swamp. 1/2 way between Baton Rouge & Lafayette & 6 mi. S of I10
