1987 350 Chev
fire46
i HAVE A 1987 BAYLINER 2550 WITH A 350 CHEV ENG.
when I crank the motor it run fine, but once I put in gear, it coughs. putt
but does not cut off, it does this for about 5 -8 secs, then it fine.
need help
fire46
motor trouble
motor trouble
Have a 1987 bayliner 2550 with a 350 chev motor, and a omc outdrive
when I crank the motor it run fine, but soon as I put in gear it cough, putt
but does not cut off, it does this for about 5-8 secs, then it run fine.
any Ideals
ziggy
Re: motor trouble
Re: motor trouble
when was the last time it had a tune up...
akwalker
Re: motor trouble
Re: motor trouble
Sounds to me like maybe the shift interupt is not adjusted correctly.
Don S
Re: motor trouble
Re: motor trouble
Going into gear, the shift interrupt system shouldn't even be used. Watch the Y bracket on the engine when you put the shifter into gear. If the Y bracket hold in the activated position, you need a lower shift cable. It's binding, and a very common problem with the OMC and Mercruiser drives
