pouring antifreeze w/thermostat removed?
Shaun78
I put 3 gallons down there. How much does it take? Can you overfill it? Where does it go if its too full?
Don S
Re: pouring antifreeze w/thermostat removed?
What are you working on???????????
Shaun78
I have a 1998 7.4L MPI.
Bt Doctur
pretty sure it like 3 1/2 gal in the motor and about 3/4 gal in each manifold/riser
Shaun78
It must be ALOT. Will it eventually overflow from the thermostat housing?
Dont worry,you cant overfill it.Charlie
Ayuh,..........
It'll either run out the Water Pick-up,......
Or,......
Out the Exhaust Risers.........
Or,......
Over flow the T-Stat.......
Shaun78
OK,Thanks as long as it wont cause anything BAD to happen. You can't overfill it. Thanks
valkyr
I've got a 7.4L Carb and i think the service manual listed something like 21 quarts of AF...4 qts in a gal, so that would be like 5.xx gallons. Now, not all that goes in the block of course, some of its for the manifolds etc
