Johnson Oil Leak
Johnson Man
I have a 1991 25hp. I am seeing a lot of oil residue coming out of the bottom of the cowling. Not sure if my float is sticking or what. Motor runs just fine. Worried about potential problems.
Gary H NC
Re: Johnson Oil Leak
Pump the fuel bulb up and look for leaks around the lines and carbs.If it was a needle and seat stuck open then the bulb would not pump up firm.
I had the same problem and it ended up being a leaky line under the top carb...
Johnson Man
Gary,
Thanks, I'll check it out this Saturday. I noticed you live in Concord. I'm just down the road in Harrisburg.
Gary H NC
Cool,I'm actually in Indian Trail now.
Let me know if you need some help locating parts for it..
Welcome to Iboats too!!!
