Trim Tab Switch Wiring
Tiki35
Hi all:
I have a 1991 Bayliner Trophy WA, and will be installing Bennett trim tabs with the EIC5000 which functions as a rocker switch, tab position indicator, and auto tab retractor. For the retract feature, I need to wire one of the leads from the rocker switch to a circuit that is only hot when the engine is on, and off when the key is off. I have the factory fuse block behind the helm and a rats nest of wires coming off the ignition switch. Any help as to where I could connect this lead would be appreciated. Would any of the fuse block terminals do what I need it to?
Thanks,
Mike
PondTunes
Re: Trim Tab Switch Wiring
What type of engine is in your bayliner? Wiring in a boat is usually done based on the engine that is installed in it.
Another route would be to grab a circuit tester or multi meter and check your fuse block / distribution block.
Tiki35
It's a Mercury 150HP. Year 2000.
Boatin Bob
You might be able to wire it up to your gauges as they normally only have power when the key is on
PondTunes
Your ignition switch is probably a 5 pole push to choke style correct? If so the purple wire from the ignition harness should be your accessory wire. Double check it with a multi-meter or test light. But that should give you a starting point.
dingbat
You may want to check your igniton switch as well. Some have an accessory wire on them
