Sea King spark plug type Question 59' 3hp
packrat56
I have a 59' 3hp (gale). What type of plug should it have? What brand is recommended? I got it started with likely the wrong plug, but it runs!!... Any advice appreciated!
steelespike
Re: Sea King spark plug type Question 59' 3hp
59,3D15B originally Champion J4J I believe the present number is J4C.set at .030.Points at .020.Do not remove the cylinder rear end cover as it is almost impossible to re install.
packrat56
Thank you steelespike, Ill hunt down that plug... Ummm, well.. that end cover, well funny you should mention that.. I did remove it and it leaks a bit.. Any advice about sealing? What to use as a sealer?
packrat56
I am trying to understand Champion letters/numbers. The closest I have found so far is a CJ6... It calls for a J4C or a J6C.. what do the letters mean when they are in a different order?
Thanks..
steelespike
As far as the end cover you might ask at aomci.org.Antique Outboard Motor Club.On the plug numbers
The number is the heat range higher number higher range. One letter is the reach and I believe the other
letter indicates electrode design.Unfortunately I'm not sure which letter.
Originally on the 2 stroke plug the side electrode only goes half way across the center electrode. (J4J) Don't know if this is the case now perhaps that could account for some of the number change.Somebody out there must know
whats up.
F_R
You aren't looking in the right place. As far as I know, the J6C is an available plug. Disclaimer: they keep changing stuff. J is the thread length ("reach") 6 is the heat range, one step hotter than a 4. C means it has copper in the electrode, for whatever good that does. The old second J meant it was for two-cycle engines to help prevent gap bridging. As mentioned, the side electrode only went half way across the center one. If you really care, the new "C" one can be filed back.
A CJ6 is a chainsaw plug, smaller in size. I'm not sure, it might have a tapered seat instead of a gasket.
If you can't find the right plugs, shoot me a PM with your e-mail address.
packrat56
I found a J4C today, just had to go to the right place... Thanks all. I appreciate the help, its fun to finally seeing it run after picking it up from a junk sale for $5 all frozen up. It runs, now I need to get it running well!
steelespike
Is the boat in your heading a Crestliner?I have a 57 Bucaneer 18ft utility.
packrat56
Steelspike, yes it is, you have a good eye! It is a
1960 12' with a 25hp evenrude. A fun little boat for sure. Have any pics of yours?
steelespike
Don't have pics at the moment.I'm second owner rode in it when it was new.
Was used for duck hunting,as a fire boat and general transportation.Usually kept inside and covered if outside.Still has its varnished mahogany seats.
Presently has a 65 Merc 500 that purrs on it.Whats the info on yours,had it long?Any pics?
There is a Larson Crestliner about to sell on ebay just use crestliner to search.
packrat56
Sadly my 60' had the wood seats removed, but the dash is intact. I am beginning to restore her, but Im still having fun fishing in the summers, so ill do a more serious restoration someday, for now I have built some hardwood bench seats, got rid of the modern "chairs" Im restoring a 59' 3hp seaking for trolling, the 72' evenrude is a good old cruser.
steelespike
A nice little boat.Have you been to the retro crestliner site.Lots of great catalogs,info,boats for sale etc.Tabs require double click.
packrat56
Yes, its a very cool site. Great photos of what my 12' should look like! I plan to restore it to original sooner or later. Yours still has the wood intact?
steelespike
Yes still has all its wood.Though the original owner replaced the mahogony
plywood seats with solid mahogony many years ago.Even the transom wood is original varnished mahogony in and out though it needs to be stripped and redone now.As I remember the aluminum has always been natural with no red bottom paint.Interior paint seems to be original light greenish gray.
Did you see the 15 footer that recently sold on ebay beautiful,imaculate
55 ,boat motor and trailer I think it went for $4,500.If I had the room I would have been begging the wife to let me bid.The cool part is she probably would have said go ahead!
