jouniraiha
Thread starter- Joined
- Oct 7, 2007
- 8
Hi, I have OMC 3.0L 1989 and something hit to it quite suddendly. I had a successful 2-day trip and parked it normally. Next weekend I tried to go out, but the engine did not start. I started to examine the problem. First I checked the ignition. I could (and still can) get spark if I put the key to run position and open and close the points. However, when cranking, no sparks.
I looked at the forum and similar type of problem was described in post http://forums.iboats.com/showthread.php?p=1491230
I ave done all the suggested tests like detaching the tach and ESA connection, but still no luck. I measured the voltage between coil+ and ground, it was 4,8 volts. When cranking, it dropped to 0V. I guess that is the reason for not having sparks, but what could be the cause and what to fix? I tried with another coil and the behaviour is the same.
The 12V cranking feed to coil should come from the starter engine solenoid, correct? Any ideas what could be wrong in there? I tried also with direct jump wire from the battery to coil+ but still no sparks.
I am out of ideas, any help? I would appreciate a lot. Weather is getting colder and I would like to get the boat winterized fairly soon.
best regards, Jouni.
