Boat owner
rndn
I went to look at a used boat to work on for a winter project last night. The used boat has an 84 Mercury 150 Black max outboard on a small boat. The boat owner stated the boat did 65 mph but that he almost had thru-hull exhaust installed for the outboard because he had heard a boat with thru-hull exhaust performed better. I didn't ask him how he planned to channel the exhaust from the prop back into the boat and then through the hull.
PondTunes
Re: Boat owner
Awesome, ask him if he got the high performance electrons installed on his starting battery! If he did you should jump all over that boat. Speaking of performance I think I'll change the air in my pontoons this year when I winterize.
mrfixitman40
Re: Boat owner
maybe he is gonna mount it as an inboard just cut cut the hole and silicone it . then just need a rudder added ,right?
Brijoe00
Re: Boat owner
Did it have a new kinibler pin, I always check that when buying a new boat. That reminds me I need to change my blinker fluid in my truck today.
commuter
Re: Boat owner
There is no way in hell he will be able to install thru-hull exhaust on that outboard without first upgrading the jackson circuits and installing a titanium finnigan pin! ;)
Commuter
Brijoe00
Re: Boat owner
Good Point, wow, I never thought about installing a finnagin pin, I hope he sees this thread or he'll be in a world of hurt.
RubberDuckie
Re: Boat owner
I hope he buys the correct muffler bearings, the wrong ones could spell disaster. If they require a left handed screw driver to install then he is on the right path. :)
57whitehouse
Re: Boat owner
When installing thru hull exhaust, it increases tension on the carberator belt. Make sure he replaces the standard belt with a high tension carberator belt.
BTW, i blew a high compression tail light gasket on my trailor yesterday. Anyone have an extra i can borrow:cool:
pgdignan
Re: Boat owner
he better ensure the di-lithium crystals are in phase and that the flux capacitor is compatible with the new titanium finnegan pin before tru-hulling the exhaust. he might also want to invest in a catalytic converter and a CO2 scrubber, can't ever have too much fresh air.
rndn
Re: Boat owner
You guys are a riot. I did end up buying the boat and don't plan on trying to install thru-hull exhaust as it sounds way to complicated(hah hah). Here's my project for the winter so hopefully I can sell it next spring.
1984 switzercraft brown with gold metal flake trim,150 blackmax oil injected merc with stainless steel chopper style prop.need interior work.comes with trailer.
kyle f
Re: Boat owner
Looks like a fun little boat. Dont sell it, buy you a 225 outboard for it and have some fun!
rndn
Re: Boat owner
I'd like to but one boat is enough. I've had my fun with a Baja that topped out at 65mph, so I'm really not interested in going that speed or faster in this boat.
MacGizmo
Re: Boat owner
Great Engine....
I got one on a 17.5 ft carrera and I can promise you to hold on when you got WOT.
I did about 70 mph in mine over the weekend:D
